ok i got it now, so basically, i will be changing where they are plugged, my rear ones will now be plugged to surround back L and R.
just to clarify, i did say "back speakers" however, they are not that far back, they are kind of diagonally next to me. its hard to explain, but now with the 7.1 setup, i will push them back further. and have the L and R 90 degrees to my seating position. i will be using the dolby chart basically.
also, adk highlander, thanks for mentioning that, i had another 2 questions:
1.) is it bad to extend 5.1 content to 7.1 using those modes (Dolby PLIIx and NEO6), meaning, am i losing quality in the sense that im not listening to it the way its meant to be heard? Im assuming its still better to use since I will now have it setup?
2.) Whats better to use, the Dolby PLIIx movie and NEO:6 Cinema modes OR the THX Surround EX and THX Select 2 Cinema (and whats the difference?)
