2 questions:
Can you "hear" the subwoofer, i.e., is it localized where you can tell the bass is coming from its position, or does the bass just seem to be "in the room"?
How loud do you play your system?
If the answer to the second question is fairly loud once in a while, I would suggest raising the small LR satellites to 100-120hz and the fairly small center to 100hz. This will prevent the onset of distortion as quickly by lowering the amount of low bass to the speakers.
If you listen at low volumes, you're probably fine, the lower the High Pass frequency, the better.
cheers,
AJ
