RSL Speaker Systems Outsider II Speaker Overview
HTKamikazee
Audioholics Sheriff
Imagine this...
You are having a party at your new pool and your best friends are getting ready to have a blast there with you. You've got the drinks ready, the food ready, but you haven't figured out how to get the most important thing a party out into the mix..... Music!
RSL Speaker Systems has a very nice solution with their Outsider II Speaker. This product has been designed to withstand almost anything. This company has been known by their sound quality products and their built quality is top notch. Check out the following features and specifications and let us know what you think!
FEATURES:
  • Polymer Infused Anti-Resonance Enclosure for increased rigidity that for cleaner sound.
  • 6-1/2 woofer with Polymer Composite Cone for tight clean bass.
  • 1" silk dome tweeter delivers crystal clear highs.
  • High quality crossover components for distortion-free sound.
  • Metal grille for maximum protection.
  • Includes Mounting brackets at no extra charge.
  • Your choice of white or black.
  • Free shipping.
SPECIFICATIONS:
  • Woofer: 6-1/2” with Ferrite Magnet, Polymer Composite Cone, Rubber Surround.
  • Tweeter: 1” Silk Dome, Ferrite Magnet.
  • Frequency Response: 50-19,000 Hz
  • Nominal Impedance: 8 ohms
  • Sensitivity: 88 db SPL @ 1 watt, 1 meter distance.
  • Recommended Power: 25-100 watts (Amplifiers up to 150 watts can be used if care is taken not to operate the speakers at maximum volume).
  • Crossover Frequency: 2,500 Hz
  • Crossover Slope: 6 db/octave.
  • Cabinet: UV Treated, Polymer Infused Anti-Resonant enclosure.
  • Gold Plated binding posts.
  • Aluminum Mounting Brackets.
  • Weight: 7 lbs.
  • Dimensions: H: 11 1/2” W: 8 1/2” D: 8 7/8” “(Without bracket 7 1/2”)
Price: $299.95/pair
Click on the following pictures to zoom in.
