There are several ways to run video signals to plasma displays and it really is dependant on what your versatility needs are.
One of the most common, and tried and true ways is the first way you listed.
6 pieces of RG-6 cable are run. Or 7.
5 pieces carry Red, Green, Blue, Horizontal, and Vertical (RGBHV)
1 piece would carry standard composite video... or if there are 2 extra cables, it would be S-video. (hence, 6 or 7 pieces of RG-6)
The RG-6 may be bundled into a mini-hi-res cable but, at 250 feet, it is much more likely that full size RG-6 cable would be run, even if it is bundled RG-6, which it normally is, so cable runs are the same.
There are many things that are possible with running Cat-5. Cat-5 can be used to send RGBHV information to the plasma directly. Not data, but actual video. While I am not sure about the likelihood of interference issues, I do know that RG-6 is open to interference as well, so you aren't protected either way.
One of the newer ways to send video is to have local MPEG to video converters at each plasma. The MPEG file is sent, as a data stream (networked) to what basically is a small computer at each plasma, then a signal starts playback of the MPEG file. The output of these boxes can be a video loop, and may be capable of real-time video, but I haven't dealt with them much, so I really can't give full specs on how they work. I do know that this is often used in theaters & the like where digital signage is actually controlled from a central office in a different state and is just loaded via the corporate network.
You should also be considering what type of plasmas you are purchasing - as quite often people are looking for the cheapest plasma for the money, instead of a plasma that actually is appropriate for what they are going to be using it for.
Digital signage is typically a computer feed with video and may include text for others to read, so I wouldn't personally look for something under 1024x768 resolution in a 42" size. Preferably 1365x768 if possible. 853x480 is almost unusable for text playback on a screen and I have heard numerous complaints from customers who were sold low-resolution plasmas because it met their budget, instead of their needs.
Where are you located? There should be commercial A/V companies in your area that have done a lot of digital signage and are willing to sit down with you and go over your options for cabling, what separates pricing, and what options meet your needs. If you guys are paying and buying cabling + equipment + labor, then your budget matters a lot, and your expectations may far surpass your budget, which a good company will tell you about. Don't underestimate how much it will cost for what you want to achieve - most people do. Best Buy is not the place to price plasmas that are going to be used in a rigorous commercial setting... or even worse, a school.
Take a look at some of the products on
www.extron.com for a good idea of one of the commercial gold standards in A/V distribution. You didn't talk about audio either... how's that going to be handled? What are you requirements?
