The prep for a RCA compression connector should be the same as for an F-connector. Typically 1/4" center conductor exposed and 1/4" dialectric and braid exposed (on some connectors it's 5/16" for each cut). The RCA connectors are a bit more critical for center conductor length, since you can't cut off excess if it's too long, and it doesn't make contact if it's too short.
