Hey everyone,
I have this setup:
Receiver: Denon AVR3312CI
Front Left & Right: Polk RTI A9
Center: Polk CSiA6
Surround Left & Right: Polk FXiA6
Surround Back Left & Right: Polk FXiA6
Sub: Epik Empire
Amp: Emotiva XPR-5 (for Fronts, Center, Surrounds)
I've had this setup for three years now and I just can never get it to sound satisfactory. The main problem I think is the center channel. Sometimes it sounds like the dialogue is trapped in a box and if you raise the volume too loud it will screech trying to get out. During pure dialogue scenes it quite frankly hurts my ears. During music + dialogue, the dialogue is too low.
I setup the speakers running Audyssey on the Denon. Since then I've played with adjusting settings over and over again. I've read a lot about what these settings actually mean but quite frankly a lot of it I just do not understand.
These are my settings right now after running Audyssey today. The only changes I made were to the distance and I changed the center speaker to Small.
Crossover Frequency:
-Front & Surrounds: Full Band
-Center: 80Hz
Subwoofer: LFE
LPF for LFE: 90Hz
Speaker Config:
-Center: Small
-Front & Surrounds: Large
Audyssey Bypass L/R: No
Audyssey Flat: No
EQ Manual: No
LFE: 0db
MultiEQ XT: Audyssey
Dynamic EQ & Dynamic Volume: Off
Distance:
-Front L: 13 ft
-Front R: 12.5 ft
-Center: 11.5 ft
-Subwoofer: 11.5 ft
-Surround L: 7.5 ft
-Surround R: 7.5 ft
-Surround Back L: 5.5 ft
-Surround Back R: 5.5 ft
AFDM: On
D.Comp: Off
Cinema EQ: On
Levels:
-Front L: -3.0 db
-Front R: -3.5 db
-Center: -4.0db
-Subwoofer: -3.5db
-Surround L: -4.0db
-Surround R: -4.0db
-Surround Back L: -6.5db
-Surround Back R: -6.5db
Does anyone have any suggestions? Anything obvious jump out as a potential problem? Do I even need the subwoofer given the size of my towers?
Much appreciate any help!
Thanks,
Frank
