Hi:
I am putting together my first home entertainment system. I should have visited here first but I took some questionable advice from my brother in law and now I have to decide whether to return everything and start from scratch or try to make it work. I am trying to make it work cause I have all the holes in the sheetrock made already.
I'm going for 5.1 Dolby Digital.
First, all the wire I ran was 18 gauge, I hope this is OK? All the runs are under 15ft with most at <8ft.
My r/l front/back speakers are all Yamaha NS-IC600 (8Ohm, 110W).
My center is a Yamaha NS-IW760 (8Ohm, 130W).
The culprit is this Kicker CVT COMPVT10 he had me buy. This is like something you put in back of your car in a box. I really didnt want to get into amps or anything, so I was wondering, since I haven't purchased a receiver yet, is there any receiver that could make this set up work? I read some information about wiring a passive sub in parallel with all the speaker lines and then setting the SUB option to "no" but Im not sure if that applies to modern receivers?
Thanks in advance.
first of all the 18ga is kind of small, I like to think 16ga minimum.... but it should work...
as for the sub, kind of a tough call on that one, were you just throwing it in a wall cavity? you will need an amp, a good option is the dayton apa150
apa150 - Parts Express Ships Fast and Ships Free, it has a built in xover and will take the signal from your avrs sub output...
Now as far as the built in speakers, not the best idea for surround sound, but if its what you have it what you have....
for a receiver anything will work, I would opt for the denon 1613 since its affordable and has good room software that you are going to need, lol...
http://www.accessories4less.com/make-a-store/item/DENAVR1613/DENON-AVR-1613-5.1ch-Networking-Receiver-w/AirPlay-3D-ready/1.html so with that and the apa150 you should be under $400 shipped...
can you put some pics up of what you have or holes where the speakers are going? as far as the sub, you should build a box for it, but the best option is to return it and buy a decent sub with built in amp, what is your budget to get this sorted out????
