I currently am using a Naim Nait 2 and Spendor S5es for the front 2 channels. I'll be using the Spendor C5e for the center and in-ceilings for the rear.
I plan on keeping Naim for my 2 channel listening and to power the 2 front channels in the setup. The receiver will power the center and 2 rears.
I am having difficulty deciding on which receiver to pick. The Sherwood Newcastle R-963 and the Yamaha RX-V657 are two possibilities. The problem with the Newcastle is the model seems to be 4 years old and I assume it will be replaced sometime in the near future. From searching this forum, it sounds as if the Outlaw receiver may be the way to go as well. Their new 1070 looks like a great product but there aren't any reviews yet on it. I'd consider the Arcam AVR300 but that doesn't seem necessary to spend that amount considering 2 channel is most important to me and will be powered by Naim.
I'd greatly appreciate some advice for this setup.
