On any receiver that doesn't have inputs for an amp can any other input be used to hook up an amp
M mountaindew11 Audioholic Intern Sep 13, 2014 #1 On any receiver that doesn't have inputs for an amp can any other input be used to hook up an amp
M MidnightSensi2 Audioholic Chief Sep 13, 2014 #2 mountaindew11 said: On any receiver that doesn't have inputs for an amp can any other input be used to hook up an amp Click to expand... You mean outputs? Make/Model? Can take a peak at the back and let you know.
M markw Audioholic Overlord Sep 13, 2014 #4 You need preamplifier, or preamp, outputs on a receiver to connect an external amplifier. No other output will do what I think you want.
H herbu Audioholic Samurai Sep 14, 2014 #6 mountaindew11 said: Yamaha Natural Sound AV Receiver Model No.HT-8540 Click to expand... If you mean Yamaha HTR 5840, it does not have any preouts you can use to send to an amp.
