Thanks guys. I had no idea that the Emotiva XPA-5 would "self adjust" to the ohms and select the appropriate impedance. I was under the impression that the impedance would have to be selected through the Denon, but it appears like when only using the Denon 4311 as a sound processor (PRE/PRO), and the XPA-5 for amplification, that I will not have to select the impedance, correct? The manufacturer recommends setting the 7 towers to large, but the concensus here and other forums is to set them all to small. Now when using a subwoofer, I need to select LFE or LFE plus mains? Can the speakers be set to small and still be in full range mode?
The system is in a small 10 x 14 den. I will be sitting about 7-feet from the speakers, so with this amp and type of speakers, it will be loud and clear
Do you all feel that the XPA-5 is a waste, and that the 4311 would power these just fine, meaning that the XPA-5 would add no head room, and better amplification with less distortion?
