I'm in the process of a HT build in the house my wife and I bought. There is a small office room (6'x6') attached to the HT room that my wife claimed as here little private area for her to have her computer and other items in. It has built in lower and upper cabinets with a corner desktop across two walls. I have convinced her to let me cut the desktop back in one corner and install a rack with the promise that she would still have enough usable desktop to have it as her office. So I leaped before I went shopping and cut off the corner of the desktop and pulled out (i.e. used a hammer and broke it apart to get it out) that piece of desktop and the lower cabinet it was attached to. Now I'm doing some searching for the ideal rack to fit in the space. I don't need a fancy show quality furniture grade rack, but I don't want some super industrial looking rack either with knock outs everywhere. I'm also hampered by the overhead cabinet which limits me to 54" max height. The best option I have found is the
Sanus CFR2127 (MSRP $799). I would have to remove the castors to make it fit but that shouldn't be an issue. It comes outfitted with numerous shelves and a front door (wife requirement) so I don't have to pay for those separately.
Now that I have that picked I went back into the office and measured to see what it would look like. Not good. My wall panel for speaker wires etc is going in the same corner. I thought I could just have the rack pulled out enough to have the panel just behind it but it makes it stick out to far and would make the room impossible to use as an office. One option I see to solve the issue is to ditch the wall panel all together and bring the in wall wiring direct into the rack without terminating to a panel. It would save some money not having to buy all those extra wall plate connectors, banana plugs, etc. I plan on leaving the rear and right side panel off the rack (right side is against the wall anyway). So I have two questions.
1. Any other options for a rack that I should consider (No small than 24U)?
2. Is there anything I'm overlooking as to why I should not bring all the in wall wiring straight into the rack and forgo a big wall panel?
