could you expand on that? i mean other than the reviews saying it was overpriced it supposedly covers all the bases of good sound. it sounds better than my yahama laying here next to me so thats a plus and it cost more too! (at the time).
for $300 A/V receiver what would be the best out right now?
Wires can't make hiss. They are passive.
Only an active component can make hiss. If you can hear the hiss easily from your rig, then it is the Panasonic unit generating it. The ratio of sound to noise is called the signal to noise ratio. 100 db or better is where it should be, but yours Panasonic is obviously way below that.
So you will only solve the problem, by replacing that Panasonic unit.
I'm not getting into receiver recommendations. I'm no receiver fan and don't use them.
Others my chime in. Some like Onkyo, others Denon, Marantz or Yamaha and some HK.
I would say do not buy at the bottom of the lines, you need to be well or a little above the midrange in the price range, no matter who you buy from.
