I finally got the last piece for my new home theater and started setting it all up last night. However after getting it going and check the picture I'm a little concerned with the picture quality. Now the HD channels from my cable company look great but the 'normal channels' look even worse on the HDTV than then did on the regular TV.
I spoke with the cable company and they helped me set up the TV to receive the proper signal's. The cable company broadcasts in 1080i and 480i. I doubt it's the TV itself but in how's it's been set up. The TV itself is a P50-G10 and was rated by CNET as a Top 5 TV in picture quality.
As I said with the help of the cable company I was able to set the TV to the proper signal reception, also set it to the proper wide screen setting, but still the 480i channels look crappy. One possible solution I thought (but not sure it would work) would entail getting a different AV Receiver than I currently have..
I bought the SONY DH800 because I figured it would do what I wanted and I wouldn't have to pay for any extra's I wouldn't need. Everything is going to be HDMI only (Cable/Blu-ray) so I'll just run everying into the reciever and then into the TV. The DH800 doesn't "upscale" and I didn't see the need for it.
Well I'm wondering if I did get a receiver that was rated as doing upscaling to 1080p, and did it well (Denon AVR-790) if I could use that to "upscale" the 480i cable signal ???
I understand that no matter what anyone does you can't turn a non HD signal into HD. All I want to do is to get the 480i signal channels to look as ok as they do on a normal TV.
I currently run HDMI from my cable box straight to the TV. So if I ran the cable box to the upscaling receiver, then from the receiver to the TV would that improve the picture?
If yes, is it still just a matter of degrees pf crappyness? Not as crappy as the current configuration, but still crappier than if you just ran a normal signal into a 25" analog ????
