Ps3 Remote Control Question
sgtmd2000
I BOUGHT THE PS3 TO FUNCTION AS MY BLUE RAY PLAYER.
WOW - IVE LEARNED ALOT - THIS THING HAS EVERYTHING, BUT AN IR RECEIVER.
SO, NOW I WANT TO USE A UNIVERSAL REMOTE (HAVE A LOGITECH) BUT NO IR RECIEVER. NYKO HAS AN IR RECIEVER THAT PLUGS INTO THE USB PORT. QUESTION I HAVE - WILL THE REMOTE WORK ON A PS3 IF I BUY THE IR RECIEVER?:confused:
jnmfox
jnmfox
You can also try this. Per the specs it will allow you to turn off/on the PS3 with your remote, something the Nyko is unable to do.
http://ir2bt.com/
bandphan
bandphan
YES:D :eek:
BMXTRIX
BMXTRIX
There are several topics on the PS3 and remotes already and your options include the Nyko Blue Wave remote, as well as the remote from www.schmartz.com and the forthcoming IR2PS3 remote which is similar to the BT2PS3 remote, except it actually utilizes 100% of the potential of the PS3 Bluetooth remote.
