Hello experts,
I have an InFocus IN3118HD that I am installing for our unit. The actual PC will be located about 300 feet away. Needing advice on the best way to run a connection with that distance. Is it possible to run a VGA that distance without signal degrading, or usb cable, or even HDMI if possible. I have seen boosters are available for VGA and USB, dont know how well they work. Thanks for any help you can provide.
