Problem with RX-V1700
penpitt
My Yamaha receiver no longer responds to any remote control commands. I have tried both the Logitech and original Yamaha remote. I even put fresh batteries in both but nothing. Everything else works fine. I am assuming the sensor on the receiver is bad. Has anyone else had a similar problem and if so is it an easy fix?
You can't assume it is the sensor.
