Problem playing Quicktime (?) streaming Internet
O
Odyssey
For years I have been listening to austinriffs.com. One clicks on "To The Shows" which takes you to a list of the shows and then one clicks on a show. At this point a blue "Apple logo thingy" shows up then turns into a typical little music slider bar.
But recently instead of playing the approximately one hour show, the slider moves across very quickly (plays the intro for 3 or 4 seconds) then stops. Also no more sound.
What gives?
O
Odyssey
Does anyone know of a forum that might be more likely to get a response? Thanks.
MDS
The symptom you describe sounds like there is an issue with the bitstream like mabye it is variable bit rate (and wasn't before) and Quicktime can't deal with it or the bitrate is higher than it supports or the stream requires a protocol that QT doesn't recognize or .... there are so many possibilities that it is hard to give any good advice without being there and seeing what is happening.
O
Odyssey
MDS, Thanks for yours. Had given up on getting a reply, but checked back to see if anything had developed.
I'll be in Austin Saturday night to hear the Greencards at Threadgill's South.
