Power conditioner with Battery Backup
Discussion in 'A/V Interconnects, Cables & Power Conditioning' started by Tyreman, Jan 27, 2013.
  1. Tyreman Audioholic Intern
    Tyreman
    Jan 22, 2007
    37
    2
    Cambridge,Ontario Canada
    Has anybody any experience with the APC AV Black J Type 1kVA Power Conditioner with Battery Backup 120V Retail
    Would be used with Panny plasma, Yamaha reciver, HD cable box.
    Or is one just as far ahead to get something like a CyberPower 1500 with a sine wave output?
  2. fuzz092888 Audioholic Warlord
    fuzz092888
    Feb 13, 2012
    8,688
    4,195
    42.3464° N, 71.0975° W
    I have a cyberpower and an APC S15. You really should verify you actually need one in the first place. Based on what you said you're using it for a battery backup really isn't necessary and the power conditioning part is really situational. If you can hook everything up and not hear any noise through the tweeters then you probably don't need a power conditioner either.
    That being said I do prefer my APC over the cyber power, at least as far as HT goes. I did have some noise through the tweeters and plugging everything into the APC made it nearly dead silent. I also have a behringer DEQ 2496 so I was able to see exactly what difference the APC made as well.
    • Like Like x 1
  3. Tyreman Audioholic Intern
    Tyreman
    Jan 22, 2007
    37
    2
    Thanks ..............about what I figured but thought I would ask.
Share This Page
  • CEDIA
