Hey all, I am wanting to go down the path of using a separate power amp for my HT and music use.
Currently using a Yamaha 663, but will plan on using the 663 as the processor, and then use a separate power amp to drive the speakers.
My speaker setup is WHarfedale DIamond 9.3 and 9.cm for fronts/centre, and 9.1 for the rears.
WHere I live, cost of audio products are very expensive, so I tend to look for either run out models, or ex demo where possible (I live in Australia).
Now I am still tossing on whether to go with these class D amplifiers, or stick to the other ones (I think Class AB??)
ANyways I was thinking of getting either something in the rotel range, or NAD, or other brands people may recommend. I am familiar with brands like the Emotiva, but being that there are risks involved to import one, I would rather stick with brands that at least I can have warranty support here in Australia should ever the need arise.
WHat are people's experience with the likes like the NAD t955, Rotel rmb 1077. I know there is a rmb 1565, how is that like?
