Oh I understand, plug my speakers into the sub inputs then connect the sub to the receiver from the output.. that makes sense ..
Other way around. Receiver into sub high level inputs, then sub outputs to your other speakers. Don't forget to buy some more speaker wire if you don't have any. AmazonBasics 16 gauge is a good deal.
I guess the question then becomes would this be an unwise thing to do?
What do you guys think would happen in terms of sound quality?
I think you'll be pleased with the result. If you're apprehensive about that Acoustic Audio sub I linked, then this
Dayton Audio 15" would also be worth considering, although more physically imposing and a little less powerful.
I still recommend the Acoustic Audio sub. If you intend to find a used sub on Craigslist or similar, don't let a popular brick and mortar brand name fool you into thinking you're getting a higher quality sub. I hope you'll post your finds back here for an opinion before committing to buy. You might find an amazing bargain like a Paradigm or Velodyne for $200. But if it's Polk or Klipsch or pretty much any 8" sub, you could do a lot better.
Sent from my LG-VS980 using Tapatalk
