I was looking at madisound and parts express, and think it would be fairly straightforward to design a 2 way from the following parts. (I initially wanted to go crazy and make a 3 way, but I don't have the knowledge).
http://www.madisound.com/accuton.html
Accuton C23-6 1.2 inch super-tweeter
Accuton C220-T6 8" woofer
I would buy a 1 cubic foot enclosure from parts express, and a premade crossover at 1600 Hz. Also, I would get one of those 2" diameter plastic ports, and some stuffing material.
The design is basically from looking at frequency response curves and sensitivities. Do I need to worry about anything like where the drivers should be laid out on the baffle, or will an aesthetically pleasing design be likely to work. Also, the crossover from parts express is rated for 8 ohm drivers, but the drivers are 6 ohm, will it still work? I don't know how to design crossovers, but imagine I could from a parts express kit.
