Hi all-
Well, I've been glued to my computer and forums like these for days, trying to soak up all the opinions and knowledge about the selection of quality home theater components, and I must say I am grateful to all those who post for the benefit of newcomers like me so I can get up to speed!
That said, I've made some choices on my components for my first-ever movie room, and would like to run them by you for discussion. I realize that a good home theater is more than just slapping a bunch of equipment on a shelf and connecting wires- the components need to work with each other and be a fit for my space.
So here's my room:
Dedicated movie room, 15ft deep by 12.5 feet wide, with some variations in corners, ceiling, etc. It's in the basement, so light is under my total control. I have 7.5 foot ceilings. I've not yet framed the room, so will stand off the frame by an inch or so from the wall, insulate and drywall all the way around. I'm going to make some dampening panels out of Owens Corning 703 or similar material for acoustic reasons. I'll only be watching dvd or HD sources in there.
Here's the equipment:
Screen- Da-Lite Perm Wall 16:9
Receiver- Pioneer VSX 1015
DVD player- Oppo PDV971H upconverting 1080 dvd player.
Speakers- SV Sound SBS-01 5.1 package
Projector- Optoma HD72.
I think the receiver only upconverts (or should I say 'handles') composites, components, and S-video, not DVI. My digital cable box (HDTV signal) supposedly will have component/composite outputs, so I'm good there. The Oppo will ( as I understand it ) upsample and output through DVI, so I could run that right to the Optoma and not even bother running it through the receiver, since the Pioneer wouldn't be able to do that anyway. My HD signal is already the way I want it, so I'd be running it through the receiver just because, I guess...
So, there it is. You can see that I am definitely on a budget, but feel also that there are great components for a first time theater builder like me to buy.
Anyone and everyone, please feel free to give feedback. Did I miss anything, take something for granted, make a totally hosed up choice?
Thanks,
Ryan!
