Just got the 822 hooked up last night. Using 4 Bergtek HDMI cables to connect sources and TV. Setup was pretty easy. MCACC works and does improve sound although there is no adjustment after other than bass/treble controls.
Front speakers are vintage Hafler 300 towers and rears are JBL HLS410. No center or sub. Return to Forever bluray with dts hd sound was very naturalwithout the hyped up subwoofer boom from my old yamaha setup. Cheap subs just don't sound natural to me. I won't get room rattling explosions but that's ok. The Haflers go down to about 70hz strong, then fade out at 35hz testing with signal generator test.
Internet radio works nice as does dlna media serving from my nas.
The one thing I do not like is that I can't set a surround mode for each input. So, if Dolby Digital or dts is present those are auto selected, that is ok. Stereo soundtracks for all inputs have to be stereo or decoded as pro logic or dts neo6. I have to turn pro logic on for stereo encoded movie files.
More to come...
Sent from my A500 using Tapatalk HD
