Pioneer AVH-X7500BT and SPH-DA210 AppRadio Review
Discussion in 'GENERAL AV Discussions' started by admin, Feb 16, 2014.
  1. admin Audioholics Robot Staff Member
    admin
    Apr 16, 2004
    172
    1,617
    I got a chance to report from our "remote studio" testing out two of Pioneer's latest in-dash receivers. I'm looking at the AVH-X7500BT, that's a single DIN $500 unit that has a 7" WVGA screen that ejects out of it so that you can use the AppRadio apps. I'm also looking at the SPH-DA210 which has the same 7" screen and is a bit fancier model. It is a double DIN unit and has the omnipresent touch screen that lets you interact with AppRadio.
    Discuss "Pioneer AVH-X7500BT and SPH-DA210 AppRadio Review" here. Read the article.
  2. pnutbutter81 Enthusiast
    pnutbutter81
    Jul 23, 2008
    13
    0
    I don't doubt the Bluetooth and app ability on this unit, but what ever happened to reviewing the video/audio performance? Maybe a test bench you can use for these to benchmark or figure out if they reach the same specs we look at for a TV? It seems more and more of your product reviews are becoming subjective instead of objective these days...
  3. zieglj01 Audioholic Spartan
    zieglj01
    Aug 30, 2010
    5,258
    1,607
    Texas
    +1 on that - it seems to be more about marketing these days.
    Also, what about safe driving - look at some driving records from
    having some toys in the car.
  4. peterro9 Audiophyte
    peterro9
    Feb 19, 2014
    1
    0
    app radio with android
    "You can use AppRadio with either Lightning or the older 32-pin Apple cable. Of course, Android works, too."
    I have this unit (avh 7500) and how it is possible to connect to the android device, to use AppRadio? it seems to me that only works with ios.:(
  5. pereze Audiophyte
    pereze
    Aug 3, 2007
    3
    0
    +2 for this. You even say "...4 x 50W per channel systems that offer plenty of amplification for your car." This is very unlike you guys to report on the MAX watts per channel. The unit is actually rated at 14wx4, which I personally would not define as "plenty". And for those of us that would like to add additional amplification, the unit has two 2v preouts which is not very good. I can deal with the fact that there are only two preouts but 2v is pretty weak.
    I know mobile audio isn't what you normally report on, so I do appreciate you bringing this side of the industry.
Share This Page
  • CEDIA
