Great Review - Thanks!
PBC - thanks for such an in depth detailed review! Excellent reading. I have a couple of quick questions:
You stated:
“Run Audyssey with the mic at the Listening position, and only that position
Check what the trim level for the subwoofer is set to in the AVR's channel level control. If it is say -4 dB to 0 dB, you’re good to go. If it’s below -4 dB, turn the gain up a few dB on the subwoofer, if it’s above 0 dB, turn the gain down a few dB.”
The manual states:
“Check to make sure your subwoofer Trim value does not exceed the positive or negative limits of Trim (typically +12 dB to -12 dB but may be different based upon your equipment). A value at the negative limit (example, -12 dB) indicates the Volume on the subwoofer was set too high. Lower the Volume on the subwoofer and re-run the auto setup routine. If the subwoofer trim is at the positive limit, raise the Volume on the subwoofer and re-run the auto setup routine.”
These seem to contradict each other – am I interpreting these wrong?
Again, thanks for such a great review.
