patio system receiver advice 6 speakers
pberm1962
i picked out 6 Polk Audio RC65i 2-Way In-Wall Speakers for the eaves of my outdoor patio, i have a thread going in these forums concerning the speakers. the speakers will be spread out evenly over a 24 by 28 foot area.they are 8 ohm speakers. i need a receiver to drive these 3 sets of speakers.we dont need surround sound ,strictly a receiver amp that will play our music. i havent been able to find a receiver that has an A B and C speaker output. is there one. will i need to buy a speaker selector switch and wire it to the A speaker output. if i need to get a seperate amp i am open to that. do i need to worry about impedence matching for the 8 ohm speakers. i have been out of the audio hobby for a long time so any advice is great. i am leaning toward a powered subwoofer as well.cost isnt really an issue but i dont want to be in the thousands of dollars
WaynePflughaupt
WaynePflughaupt
Assuming the receiver you’re talking about will be dedicated to the patio system, as your post implies, I’d suggest getting a 7.1 channel receiver that has a “7-Channel Stereo” mode. That would make the four back channel speakers play the same thing as the front left and right.
If that doesn’t work you’ll probably have to get a multi-channel amplifier from someone like Home Theater Direct.
Regards,
Wayne A. Pflughaupt
pberm1962
thank you i will look into a 7.1 ch receiver with 7 ch stereo mode. that would be what i want
