I got one of these, and I seem to have issues with it.
Video/Audio Splitter - HDMI® M to HDMI® F X 2 - Monoprice.com
My PC is connected to TV via receiver. My receiver needs to be on, irrespective of it being used. So even while browsing, it is on. By using a splitter I can connect to PC directly or via receiver and i can use my TV remote to switch between either. Hence i can switch off the receiver when not needed.
Here is what i am trying.
(a) Split input source coming from PC using the splitter. Splitter Out 1 goes directly to TV input HDMI 1, Out 2 goes to HDMI 2 in TV via the receiver. Switch between both using TV remote.
However, both do not work!!
However, if i connect as mentioned below, i get some weird unexpected results.
1. Splitter OUT 1 to TV HDMI 1. OUT 2 is not connected. - It works.
2. Splitter OUT 2 to TV HDMI 2. OUT 1 is not connected. - It *does not* work.
3. Splitter OUT 1 to TV HDMI 1 along with Splitter OUT 2 to TV HDMI 2, and use remote to switch between HDMI 1 & HDMI 2 - Both works.
On top of this, I got it to work couple of times, when connected as mentioned in (a). I remember one time it worked when connected via the receiver. I triple checked the connections. When I switched the TV input selection using remote, the other wasn't working. Switched back to this and neither was this working anymore.
Whats happening? What am i missing?
I was under the impression that I do not need an active splitter for my needs, read a few threads earlier at AV forums.
