<font color='#000000'>OK, its time for my 2-cents. I prefer a digital coax and here's why.
1) You're almost guaranteed a good connection with a coax. Unlike the new "trap door" fiber optic connections that are being put on the ass end of the Sony Receivers and others, the Coax connection is solid and a proven design. What happens with the new "trap door" fiber optic connection design is that after two or more installs/uninstalls, the door brakes. Well, the door is also used to hold on the fiber optic cable, and without the door, that connection is lost. Your only hope after is to rig the cable on with adhesive, or use another connection and change sources on your AV equipment.
2) Each end of a fiber optic cable is just that, an optic. Optics are prone to scratches and breakage. If you accidentally mess up an end during installation or handling, you're screwed out of an expensive cable. Yes, even an "audiophile" can screw up connecting this cable. What can happen, for example, is you may be in a tight area (like behind a wall unit), and you can't see the back of the equipment. So now your forced to blindly try to install the fiber optic connector, which is obviously, orientation sensitive. You feel, you prod, and you push, but it ain't going in : ). Then suddenly, with all that poking around, you snap off the lens, or scratched the lens without knowing it.
My thought is stay coax. You just plug the cable in and there you are. No fussing with orientation, trap doors, and the worrying about the cable falling out due to it's own weight.</font>
