I'm seeking advice for my home theater layout. The attached image is my plan as of now, but I'd like any ideas you all may have. Nothing is prewired except the cable outlet for the TV placement. I will have easy attic access to run wires if need be.
Equipment is as follows:
Fronts - Polk TSi400 floor standers
Center - Polk CS10
Sub - Polk PSW111
Surrounds - Polk OWM3
Receiver - Pioneer VSX-519V
BluRay - PS3
Remote - Harmony 880
TV - 70" UHD to-be-purchased - will be wall mounted
Ceilings are 9' and room dimensions are listed on the image I attached. I'm open to any and all ideas. The home is still being built so it'll be a blank canvas. I've also attached a couple images of the actual room, one of the room itself, another showing the open side of the room with the stairs.
Thanks!!!!!
