Here we have the the new Onkyo 11.2 3020 Atmos AVR with a MSPR of $2,399. It is their top of the line AVR. So what are your impressions of this AVR? would you line to get one or is it to steep of a price for you? What it is and what is does: Power Output 0.05% (20 Hz20 kHz, Half power) All Channels 135 W (8 Ohms, 20 Hz-20 kHz, 0.08%, 2 channels driven, FTC) 160 W (6 Ohms, 1 kHz, 0.7%, 2 channels driven, FTC) Dynamic Power 300 W (3 ohms, Front) 250 W (4 ohms, Front) 150 W (8 ohms, Front) THD+N (Total Harmonic Distortion + Noise) 0.08% (20 Hz-20 kHz, Half power) Damping Factor 60 (Front, 1 kHz, 8 ohms) Input Sensitivity and Impedance 200 mV/47 k-ohms (Line) 2.5 mV/47 k-ohms (Phono MM) Rated RCA Output Level and Impedance 200 mV/470 Ohms (Line Out) Phono (MM) 2.5 mV/47 k-ohms Maximum RCA Output Level and Impedance 4.6 V/470 Ohms (Line Out) Rated XLR Output Level and Impedance 400 mV/470 Ohms (Pre Out) Maximum XLR Output Level and Impedance 9.2 V/470 Ohms (Pre Out) Phono Overload 70 mV (MM, 1 kHz, 0.5%) Frequency Response 5 Hz-100 kHz/+1 dB, -3 dB (Direct Mode) Tone Control ±10 dB, 20 Hz (Bass) ±10 dB, 20 kHz (Treble) Signal-to-Noise Ratio 110 dB (Line, IHF-A) 80 dB (Phono MM, IHF-A) Speaker Impedance 4 ohms16 ohms Video Section Input Sensitivity/Output Level and Impedance Video 1.0 Vp-p/75 ohms (Component) 0.7 Vp-p/75 ohms (Component PB/CB, PR/CR) 1.0 Vp-p/75 ohms (Composite) Component Video Frequency Response 5 Hz100 MHz, -3dB Tuner Section Tuning Frequency Range FM 87.5 MHz107.9 MHz AM 530 kHz1,710 kHz FM/AM Preset Memory 40 stations General Power Supply AC 120 V~, 60 Hz Power Consumption 10.7 A No-Sound Power Consumption 145 W Standby Power Consumption 0.1 W Dimensions (W x H x D) 17 1/8" x 7 13/16" x 18 3/8" (435 x 199 x 466.5 mm) Weight 48.5 lbs (22.0 kg)
