Well tell me how did they mesh together. Does the sig benefit from the hsu sub
Yes, the Hsu subs does have a significant advantage over the Signature towers in bass performance. They would make a good pairing.
You say you like loud music, well the Signature speakers can do that. Like I said in the
Fluance review, you will want some space between the Signature towers and listening position. The sound doesn't really come together when you sit close to it, but, at 10 ft or so, the sound comes together, and it is a solid speaker.
However, if you have to sit close to the speakers, there are better choices. The
Hsu HB-1s are quite good. I see some
Klipsch RB-81s left at Amazon for a good deal, those would be very powerful for bookshelf speakers! Here are some
RB-61s, that would also have some very good dynamic range for the price. If your receiver has pre-outs, some
JBL LSR308s would be a fantastic choice. Here are some
Klipsch RP-160s for something a bit more updated over the RF speakers, I think those would hit very hard. Another good powered Monitor choice would be these
Mackies, but, like the JBLs, you would need a AVR with pre-outs to use those. Also, I had the chance to hear some
Hsu CCB-8s today finally, they have spectacular dynamic range, although they would be a bit over your budget.
