I have a Denon 3808ci reciver and recently it stopped working it powers up but i get nothing out of the speakers, but if i connect head phones i get sound on the head phones??? Anyone with some advice??
Thanks, Dan
I seem to remember we had one of those receivers do that a few months back.
First make sure that the HDMI audio out has not got set to on. This will make your speakers silent, but the TV will output audio. To hear sound from speakers connected to the receiver HDMI audio out must be set to off.
I trust you have done a reset. This is likely to have low yield, but worth a shot.
Now if the above fails, and your receiver has failed: -
The fact the headphones work, says the preamp is working.
Now the most likely issue would be that the high voltage power supply board has failed. The pre amp is low voltage and the power amps high.
There is a thread about this receivers problems on the AVS forum. The problem is that people have put a lot of money into repair of these receivers and not solved the problem.
Here is what I would do.
See if there is audio at each of the pre outs. If there is then the processing board is OK. This will confirm my hunch about power supply issues.
If the pre outs are working I would keep that unit as a pre amp, and buy external amplification for all channels. That way your receiver will not be a total loss. The big benefit is that you will have a much better system.
Contrary to others views on these forums, receivers have poor power amp stages. Good external amps will see receiver amps all the way home.
I assume this receiver is out of warranty, as they only carried a year, and they are out of production.
If this unit has failed, I would use it as an excuse for a big upgrade.
I personally would absolutely never consider using a receiver to power speakers. Absolutely never.
