Hi everyone, I have recently invested in a sound system and I'm very pleased with the sound quality, but I'm concerned that in the future I might play too loud for the receiver to handle and as of now I'm not really sure how loud I can play (as I understand it's the receiver that often restrict a system because of the signal quality getting worse the higher you play, right me if I'm wrong
So this is where I need your help,
1. How high can I crank up the volume without the system failing on me?
2. Will I get an improvement if I buy an external amp or am I already at the limit of what the speakers can handle?
3. How will an amp effect my system since it's 5.0 do i need to take the surround and center speaker into consideration?
4. If I decide to buy a amp, which one do you recommend and how much of a gain can I expect?
The system I'm using is a proson inphase 5.0 (but I'm planning to buy an active sub soon, so feel free to suggest
), you have probably never heard of them so I will list the specs here. The receiver I'm using is an Yamaha RX-775 and it's the european model since I'm located in Sweden If you don't want to search for the specs for your self i will list them too
Front speakers (IPF-6):
Construction: 3 bass reflexes backward Goldplated Bi-wiring terminal
Ability to change the crossover on the midrange / tweeter
Tweeter: 4 x 1-inch Super Audio tweeter with Neodymium magnet
Midrange: 2 x 6.5-inch midrange
Base: 2 x 6.5-inch subwoofers
Impedance: 4 ohms
Frequency range: 28-32 000Hz
Sensitivity: 92 dB
Max Power: 250 W
Dimensions (HxWxD): 1100 x 280 x 345 mm
Weight: 22kg
Center speaker (IPC-6):
Construction: 4 Bass Reflex backward
Tweeter: 2 x 1-inch Super Audio tweeter with Neodymium magnet
Bass / midrange: 2 x 6.5-inch bass / midrange
Impedance: 4 ohms
Frequency range: 40-32 000Hz
Sensitivity: 92 dB
Max Power: 180 W
Dimensions (HxWxD): 225 x 525 x 230 mm
Weight: 7.5 kg
Surround speakers (IPS-6):
Construction: 2 Bass Reflex backward
Bass / midrange: 1 x 6.5-inch bass / midrange
Impedance: 4 ohms
Frequency range: 50-32 000Hz
Sensitivity: 92 dB
Max Power: 100 w
Dimensions (HxWxD): 225 x 326 x 165-185 MM
Weight: 3.9 kg
Yamaha RX-775:
Amplifier Section Channel 7.2
Rated Output Power (1kHz, 1ch driven) 160W (4ohms, 0.9% THD [European Model])
Rated Output Power (20Hz-20kHz, 2ch driven) 95W (8ohms, 0.09% THD)
Maximum Effective Output Power (1kHz, 1ch driven) (JEITA) 160W (8ohms, 10% THD)
Dynamic Power per Channel (8/6/4/2 ohms) 140/180/210/250W
