Thanks so much for your quick response. Here is how I've connected everything - can you recommend what I need to change? I'm still confused.
HDMI In #2 on the TV connected to HDMI Out on receiver
HDMI #1 on receiver connected to DirectTV box HDMI (only one port here - I am assuming it is HDMI Out?)
I have a Logitech universal remote that lets me assign inputs for each device and programmed it so that DirectTV plays properly thru the speakers when I have:
TV = HDMI 2
Receiver = HDMI 1
Any tips on what to change would be greatly appreciated! I have 4 places for HDMI on the TV, several on the receiver, and only one on my DirectTV box.
Right, so the DirectTV box is the
source of the sound and it is output over HDMI to your receiver. The receiver keeps the sound part for itself and directs it to the speakers attached to the receiver. The video is forwarded to the TV from the receiver's HDMI out to the TV's HDMI 2 input.
Now for the internet streaming, the TV itself is the source of the audio and video. It will play both the audio and video unless you tell it to direct the audio somewhere else (the receiver).
I found the TV on LG's website and the specs say it has an optical digital audio out. So you need an optical audio cable from the TV's optical digital audio out to an optical input on the receiver. Digital audio inputs on the receiver need to be 'assigned' to an input selector. Say your receiver has an input labeled 'TV' and you want to use that for watching and listening to internet streaming content from the TV. Assign the optical input to the the 'TV' input selector (the receiver manual should show you how, it's usually very simple) and the receiver will be playing the audio from the TV whenever you select the TV input on the receiver.
You can set up another macro on the remote to automatically switch to the input for watching the internet content coming from the TV.
