Hi, everybody,
I used to lurk here a lot but drifted away. I come back hoping you can give me some advice.
I'm installing a small system at my folks' place (11x14 room) and I need help choosing a receiver. For speakers, I already have a couple of Choral Focus 710's and I just bought a used Choral Focus CC 700 V.
They have a TV; I don't know much about it except that it's probably around 60" and is probably 2-3 years old. They have a cable box and I would like to possibly run digital out from my macbook pro but I would be fine with MBP>Audioquest Dragonfly>1/8"toRCA>receiver (what I'm doing now).
They also have a BluRay Player.
I don't think I'm going to do a 5.1 system but would like to possibly upgrade to 5.1 in the future. I would like HDMI switching. Is it possible to do over the air digital tv through the receiver? I have a budget of about $300. I'm open to buying used. I was thinking of a Marantz 1403.
Could you also recommend a sub? There are neighbors to think about in the summertime but not so much in the off season.
Thanks!
Will
