Good article, another way is to use a finish nail, remove the molding and use a long finish nail to pop in every few inches until you find the stud, if there is basebaord heat it will be mounted 3/4-1" above the floor grade you can pop the nails through in that space....
When I do a wall mount tv, I mark the wall where I want the center of the tv, then I mark the near by studs, then remove the sheetrock in that area, say 32"s x 11 or 16 x 11 depending if my center fell between 2 studs evenly or close to a single stud...
After cutting my nice rectangle hole I can see the edges of my studs, I install a 2x12 between the 2 studs at the height my tv mount will bolt up, it sits inside the wall flush with the sheetrock {or sit it in the wall a 1/2" and put the piece of sheet rock back over it}, I paint it the color of the wall, alex caulk it all in nice and neat and while Im in there install the tv box.. now the tv mount has a solid surface to mount to, so if a drunk friend trips and falls on the way to the bathroom on new years eve when she grabs the tv to catch herself from falling she doesn't rip it off the wall sending it smashing it to the floor.. Its a little work but well work it...
When I built my house, we marked where all the wall hungs would be and framed them in under the plaster , so every spot I thought I would hang a tv I added a few 2x6's just in case, I also hid the wires back there just in case, to date I have 3 untouched inside the walls but have used all the others....
Anyway, nice article. I no longer fret about finding studs since I got my deep wall scanner dtect 150, it works really well, electric wires trick it sometimes but for the most part it is awesome, finds water pipes in cement walls, studs, rebar, electrical, ect... But something much cheaper than that would be this camera {my son has one it works well}
http://www.amazon.com/dp/B004ZWFOEQ/ref=biss_dp_t_asn and a set of fish stix
Amazon.com: fisch sticks: Industrial & Scientific drill a hole big enough for the cam, tape it to a fish stic and send it in, take a look around..
