Paradigm Cinema Speakers Preview
admin
Audioholics Robot
Staff member
Regardless of your needs, the Paradigm Cinema Speakers has a solution for you. Especially on a budget. With 5.1 systems starting at $1000 and tons of upgrade options, users should find all they need. From the satellite Cinema 100 speakers to the MTM Cinema 200 speakers, to the much larger MMTMM Cinema 400 speakers, all room sizes are pretty much covered. While the drivers don't change, the level of output and extension of bass does. Even those looking for a single speaker LCR have an option in the Cinema Trio. Add to that the compact Cinema Sub and Paradigm has set their sights directly at the budget conscious crowd that doesn't want to settle for poor sound.
Discuss "Paradigm Cinema Speakers Preview" here. Read the article.
