minor correction to listing
A great list of cool gadgets - what more would one expect!
I did see a minor clerical error:
WD My Passport for Mac
Designed as an upgrade of the its T1 surge suppressor, Tributaries’ new T1A is a single-outlet device designed to provide 540 joules of surge suppression with an added line filtration circuit for clean power. The T1A is engineered with the X3 MOV (Metal Oxide Varistor), which are designed to blow before your gear does. The compact size of the T1A, makes it ideal for protecting subwoofers or any other type of household electronics that operate with solid-state electronics. This is a great stocking stuffer for the electronics guru in your life. And if you need a new HDMI cable that supports Ethernet and ARC, check out their new Series 6 Cables
Price: $20 More info
The listing for the WD Passport is describing the Tributaries T1A surge suppressor.
