He said the olive does not have artwork in it's database, but I believe you need to have it hooked up to the internet via a ethernet cat5 cable, as my older Escient Fireball is. If your music is by obscure independent artists, or often classical discs have odd, obscure details, they are not logged anywhere, so you are sol on artwork. BUT. 98% of music that I listen has artwork that can be found on the Gracenote service that Escient uses. Having the artwork is nice, but has little to do with the playback of the music. Also, a music server will reproduce sound as good as any digital source you can find- why wouldn't it?
Also, this is their entry level model with 500 gb- I believe you can go up to a couple of TB if you spend the coin.
Gosh, 500gb will hold a lot of cds..........
it would be disappointing if it didn't display on a TV, as well. If you are in the sweet spot of your system, to not have it up on the screen would be a downside, at least to me. My escient only does OSD on my TV, and it is not good for background music as you have to fire up the plasma to see what you are doing. A server should have both options for navigating, imho- a display on the server itself, and the ability to bring it up on the TV, too.
I do like that olive has adopted a trayless cd player option. It seems much more efficent than a tray clunking in and out, to me.
