use as on-wall speakers for kitchen?
How well are the EMP ECA-4 likely to work as "B" speakers mounted up on the walls in a kitchen in an A/B configuration (with Axiom M22s on the A output)?
My concern would be that the lower sensitivity might make it hard to get
the volume levels equalized in an A+B configuration.
(Dealing with cross-over could also be a little tricky here...
Some of the bleed-over of the 60Hz-100Hz range from the adjacent
room might help some, although things obviously won't be perfect...)
I've also considered the Orbs and the Cambridge Soundworks cubes,
but neither of those claim to go quite as low in frequency, making
the cross-over issues harder. I'd rather not cut holes in the walls
until I redo the kitchen in a few years, so in-wall speakers
and the Axiom W2 are probably out...
