My DIY speakers "J&N"
Discussion in 'DIY Corner - Tips & Techniques' started by jororaitchev, May 17, 2017.
  1. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    Archimedes used the floating force to find out if there is silver in the royal crown.
    I tried to explain to you that the specific resistance of MDF in my measurements is taken in pure weight units and removed from the total weight of the water in the cabinet volume.
    Joro
  2. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    And continue with my "clever trick";
    Let's assume that the density of MDF is 0.75 kg. of cubic decimeter/ average value by tables /. This is 75% of the actual reduced volume.
    The reduced volume error is:
    3.5 / 0.75 = 4.6 liters actual reduced volume, and the whole volume is 43-4.6 = 38.4 liters.
    The total error of 39.6 liters is 1.2 liters or -3.1%.
  3. MrBoat Audioholic General
    MrBoat
    Nov 13, 2016
    1,311
    574
    I understand what you are saying, jororaitchev. Initially, I was more concerned with the volume before the enclosures were built during the design and drafting phase. It never occurred to me one would measure after with something like a speaker cabinet. I have seen Archimedes principle applied for displacement, or the volume of solid, irregular shaped objects. I have used Archimedes principle to measure lard for baking to keep from having to pack a measuring cup with the fat.
    In the case of ship building, these volumes are known for the most part, with an adjustment feature built in by way of added or removed ballast perhaps, provided they are relatively close to start with. A ship hull comes from the architect with a designed waterline before the first piece of material is cut. When the boat is launched, it will be stated that she "rests on her lines". . . .hopefully.
  4. MrBoat Audioholic General
    MrBoat
    Nov 13, 2016
    1,311
    574
    Dry beans are very settling due to their irregular, smooth shape, their weight and their slippery and hard exterior. You could essentially stir them into place. They also come in a variety of sizes to match scale.
    Ok, I am not totally serious but, it would work in a pinch if one did not want to source or construct something more complicated. I grew up knowing some pretty resourceful thinkers that could make due with whatever was around them with some surprisingly accurate results. Those left/right brain types.
    Dry sand can even be used to measure volume, as it is fluid enough to find it's way through the hourglass.
  5. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    • Like Like x 2
  6. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    I have an idea to make a new project to in the base there should be two 10" loudspeakers - just an idea. They look like animals, maybe dinosaurs, but important are 20Hz. 2.jpg 20.jpg
    • Like Like x 4
  7. KEW Audioholic Spartan
    KEW
    Jul 12, 2009
    6,056
    2,140
    Jowjah
    You need to raise your ceiling, scale up this model so they tower over you and build the speakers into the abdomen and chest cavities!
    [​IMG]
    KEW,
    • Funny Funny x 2
  8. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    My high ceiling criteria differ from reality,this "Lego" is very good!
    • Like Like x 1
    • Funny Funny x 1
  9. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    And the original model will look like this;
    • Like Like x 2
  10. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    I continue with the collection of the cabinet;
    Now I can make the exact measurement of the volume. And that's 31.5l, just as much as I need!
    Oh, l forget to show you what I did to get that volume!
    I maked a filter compartment (for the MW and TW), the W section will be in the box;
    I previously make the last layer-10 mm MDF / to get a sandwich construction / on the front panel and the bottom;
    Last constructive action ;
    After 10 hours I will install the last layers of 2 x 4 mm bent MDF;
    • Like Like x 1
  11. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    A small structural change for the side panels, last layer is 1 x 4 mm plywood and everything is re ady for the measurements.
    • Like Like x 1
  12. KEW Audioholic Spartan
    KEW
    Jul 12, 2009
    6,056
    2,140
    Jowjah
    It a delight just to look at your constructions!
    Woodworking porn FTW!
    KEW,
    • Agree Agree x 1
  13. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    Thanks!
    And a risky picture (everything is supported by gravity), how look for compared to the frontal columns, are not on one line, but I rely on your imagination.
    • Like Like x 3
  14. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    Several steps to the moment with measurements ...
    • Like Like x 1
  15. KEW Audioholic Spartan
    KEW
    Jul 12, 2009
    6,056
    2,140
    Jowjah
    KEW,
  16. jororaitchev Junior Audioholic
    jororaitchev
    May 17, 2017
    50
    54
    If we have to associate with the white, it is with the helmets of the warriors of "Star Wars".
    This is the project of the rear speakers, will finish it with "Bird's eye view".
    • Agree Agree x 1
Share This Page
  • CEDIA
