I am in need of advice for selecting a new AVR to be used primarily for multi-zone music. I currently have Denon 4308 and need to retire it as the web control has not worked since day 1 and I can’t take it anymore. The unit is in a rack in my basement and I need to be able to control the unit from my kitchen, deck garage, etc. What I plan on doing is dedicating the 4308 to my HT where I can control the 4308 with its remote in the same room.
My plan is to buy a new multi-zone AVR that has web control/ iphone app. The unit must have 3 zones, a 4th is a plus. With the 4308 dedicated to HT my set up would be as follows:
• Utilize the main zone to power at ATON speaker selector ( controls Deck, Kitchen, Garage)
• Use Zone 2 pre outs connected to Anthem MCA 20 Amp and Revel F32 Speakers
• Use Zone 3 pre outs connected to Anthem MCA 20 Amp and Bose 701 Speakers (soon to be upgraded)
• Zone 4 -future expansion
I have been researching the following AVR’s
• Denon 4520 (first choice not sure if it’s worth the money)
• Denon AVR-X4000
• Marantz 7008
• Marantz 6008
• Yamaha 2030
• Yamaha 3030
My dilemma is since that I am using amps on 2 of the zones is it worth the money to spend on the 4520 or 3030? I am also not concerned with the 4K Video Scaling, 3D video processing or other bells whilstes as I mainly will use this for music. My main concern is enough power for the un-amped zones, airplay, internet radio and control via a web browser.
For those that may be interested I have tried everything possible with the Denon to connect with my network, several different routers, various settings, new cables, etc. I talked to Denon support a 100 times, it will work for 3 -5 days then disconnect from my network. I have the DHCP set to off and have set a static IP so not sure why
Bottom line is I don’t want to spend 2k plus if I don’t need to , I don’t want to waste money on features I dont need, I will use the system primarily for music , I need 3 -4 zone capability and
Any input is appreciated on what AVR you think would best fit my needs.
Thanks in advance
Robbo
