Hi guys. Im new to Audioholics.
I recently bought and setup my Infinity Alpha series speakers (A50, A20, C37, and A1200s). The main generator of bass in my system is the pair of Infinity Alpha 50s. Upstairs, poisitoned about 1 foot from the wall, and sitting on carpetting floor (this was the 1st floor, ie. I have another level below) they had a TREMENDOUS amount of bass, enough to satisfy most people without the addition of a subwoofer.
However, once I moved them downstairs into the basement (carpetted floors, finished walls, with oak panels circling the sides of the room) I lost almost all of my bass response. I tried putting them in corners, moving them forward, facing the side walls, and even back walls. The side wall facing position makes a lot more bass than front facing. But the back wall facing makes the most bass (about 80% as much bass as when they were upstairs) at a loss of high frequency clarity.
But the problem is, when firing into the wall, or sideways, I do not feel the low lows much at all (ie. the tones that virbate through your gut and are very low frequency sounds). I also get somewhat of a boomy bass response, although very little boominess is present.
Also, would adding the Infinity Alpha 1200S sub (12" driver, 500 watts RMS. 28Hz - 150Hz) make a HUGE difference?
What is causing the lossof bass here? The fact that the 50s are front firing, or the oak panels. etc. etc.
ANY help is very much appreciated as no man will be happy without his ample supply of bass
Diagram is included
