Okay Folks, it looks like that I am going to order me a set of these:
http://www.samash.com/recording/studio-monitors/resolv-rxa6-2-way-active-studio-reference-monitor-with-air-displacement-ribbon-tweeter-single-srxa6xxxx-p
The price is just right and I want to hear the ribbon tweeters. If for some reason they are not to my liking, then I can send them back. The only caveat is return shipping is on me if that be the case. So, I also need to order a balanced DAC. Which one should I order?
The Lexicon Alpha really looks a bit complicated for my tastes. The Behringer UMC22 looks more practical for me. But, the simplicity of the Peavey USB Audio Interface looks appealing. However, the Peavey does not have headphone out in which I need. So, perhaps the Behringer UMC22 is the better way to go?
So if I were to order the Behringer UMC22, then which cables/adapters do I also need to order to hook up the Samson powered monitors linked above? Am ready to order as soon as I have it all together. Really appreciate all of your help folks. Thanks!
Cheers,
I will be interested to see what you make of those. Those tweeters are AMT drivers. They are pleated ribbons, that squeeze out the air like the old Heil driver.
They are tough to implement as free air resonance is 2.3 KHz. The manufacturer recommends slope of 12 db per octave at 5 KHz. So if you used a fourth order electric crossover you could cross at 3.75 KHz. In any event that woofer is going to have to run higher up than I suspect one of that price can.
Phil
