When you want to take the party outside, there is nothing better than a pair of reliable outdoor speakers. The CL60-T2 Outdoor Satellite Speaker is an example of what a good outdoor speaker is.
This speaker features one 6 1/2" C-CAM® bass driver and 2 x 1" C-CAM gold dome tweeter. C-CAM is an innovative alloy originally conceived by the aerospace industry for use in jet engines. Its CL cabinet is a heavy duty bracket, designed for 175-degrees of horizontal or vertical rotation. This unit also features magnetic end caps to protect the bracket terminals. Its solid, sealed, high density polypropylene enclosures are treated to withstand all types of weather. A mask is also included just in case you want to paint them to match the surroundings. Check out some of the features and specifications.
FEATURES:
- Quick and easy installation.
- High performance C-CAM tweeter and driver technology.
- Robust solid sealed, high density polypropylene enclosure - UV rated.
- Full installation flexibility: 175º rotational bracket, (it also features angled sections and screw holes to provide corner fixing.)
- 15º angled wedge supplied for additional bracket versatility.
- Anchor point for security chain attachment.
- ABR (Auxiliary Bass Radiator) for added low frequency punch.
- Aluminium grilles prevent rust.
- Textured white and black finish, paintable to suit décor (paint mask supplied).
- Rotational ‘M' logo to align with portrait or landscape positions.
SPECIFICATIONS:
- Frequency Response: 63Hz - 30KHz
- Sensitivity (1W@1m): 88 dB
- Impedance (nominal): 2 x 8 ohms
- Maximum S.P.L dBA (per pair): 108.8
- Power Handling (RMS): 2 x 50W
- Amplifier Requirements (RMS): 15 - 100W
- Drivers: 1 x 165mm (6 1/2”) C-CAM® bass/ mid-range driver with dual voice coil / 2 x 25mm (1”) C-CAM® gold dome tweeter.
- External Dimensions (H x W x D): 12-13/16" x 7-5/16" x 7"
- Total Depth Including Wall Bracket mm (inches): 9-1/4"
- Total Bracket Pivot Angle: 87.5 degrees (from central position)
- Fixed Angled Block (portrait orientation): 15 degrees Cable
- Connection: 2 sets - Gold plated 'push' type terminals.
- Environmental Protection Rating: IP55
- Finishes Available: White/Black
- Weight Packaged: 11.04 lbs.
Click on the thumbnails below to zoom in.
Now that summer is near, are you going to give these puppies a try?
