Media Room basement build
Swerve
Swerve
Found that my second layer of insulation- Knauf R12 fiberglass was sagging a bit in my joist cavities. It's lighter and flimsier that the Roxul Safe and Sound I used in the first layer.
I can't let the insulation slowly come into contact with the drywall furring channel over time, so picked up some Simpson Strong Tie Insulation Supports, IS16-R100. Took a few seconds and did the trick.
for those in the US, home depot also stocks them. Simpson Strong-Tie 16 in. OC Insulation Supports (100-Pack)-IS16-R100 at The Home Depot
Lowe's has similar ones. Shop 100-Pack 24" Insulation Supports at Lowes.com
manfrog
If you are still around curious how the build turned out....a lot of similar concerns on my future build :)
