Currently I have a 5.1 setup with two Martin Logain 15 bookshelf, a Motion 8 center, a ML Dynamo 500 sub and two Home Theater Direct bookshelf speakers for the side channels. I have the Marantz 5008 receiver.
I'm looking to upgrade the system and going to a 7.1 system. I'm thinking about adding 4 Martin Logan Electo-R 8" in-ceiling speakers to replace the HTD side-channels and to add two rear surround channels.
I'd also like to upgrade the Martin Logan Center Channel to either a ML 30 or ML 50XT.
The system is an an open floor plan living room with a kitchen behind it and a hallway to the side. I know the Dynamo 500 is under powered for the size of the room, but the wife already doesn't like subwoofers or bass. Still I think a 700 would be better and may add as a second sub in the future (not right away though).
Questions:
1. If I install the 8" ML Electro-R's will that blend well with my Motion 15s? The Motion 15's only have 5.25 drivers, so would that be out of balance or sound off to have 8" woofers in the side and rear surrounds and 5.25s" in the front? Should I use the Electromotion In-Ceiling 6.5s"
(note: sometimes I realy wish I had the ML 35XL's on the side to get the 6.5 drivers,but they weren't out when I bought the system and my wife really liked the small size of the bookshelves)
2. For my setup, would I get better mileage out of putting the new in ceiling's in the rears or adding front-height speakers? Similar to question #1, where would I get the best results if I do go with a larger 8" driver?
3. I've even thought of buying 5 new Electro-Rs and installing a switch so I could toggle between the 7.1 with front-heights and front-rears; but that's probably overkill and the wife will say no
Overall I love the ML speakers. crisp and detailed high's, great vocals. Sometimes I wish I'd get better low and mid bass; although I think part of that is just with my center channel vocals, redenering with even smaller 4" drivers. Hoping a new larger center will help this.
If anyone has any other great ideas outside of this let me know!
thanks
