Thanks for the replies, I really appreciate it. I can select different sources for Zones 1 & 2, its just that I only get sound right now when I have the same source for all zones turned on. This is probably the result of something I have done, not the design of the receiver.
The SR5008 has a powered Zone 2 & only running 5.1, it should supply plenty of oomph for the Zone 2 speakers. It was a while ago, but I believe w/ my Denon I had the Zone speakers wired directly to the AMP so it may be the speaker selector- I believe it is a Russound but not sure. W/the Denon, I got plenty of volume out of the Zone 2 speakers, I just could not control the volume or turn on/off each individual speaker which is why I got the selector w/ volume control.
What do you all think about switching to 7.1 then either wiring the amp or speaker selector to the Surround Back speaker output terminal & not the Zone 2 RCA connectors? That is one of the options for wiring the Zone 2 speakers in the Owner's Manual & I believe that is what I did w/ the Denon & it worked well, I just couldn't control the volume or turn off each speaker in Zone 2.
Thanks again for the advice.
