First off, on the back of your receiver, locate the jack labeled either "LFE" or "Sub Out"
Second, on the back of the sub. locate the jack labeled "LFE". Turn it's level a little more than half way.
Use an interconnect to connect the two.
Then check your receiver's manual for how to tell it you have a sub connected. That' s what going to taka a little reading on your own.
