MacManNM said:
If you care to go back and actually read the posts, I am the one who stated that the Le of a driver has no affect in this application, not you.
I will quote the posts at subject here, in chronological order, in an attempt to clear up this apparent confusion:
(1)WmAx: Le is irrelevant in a subwoofer. Le dictates the high frequency response(it acts as a 1st order low pass filter). It is not a factor for woofer quality.
(2)MacManNM: You are totally wrong on this one. The Inductance of most woofers is too small to make a difference. A 4-ohm speaker, with 23mH inductance won’t start to cut off until around 1.7KHz. Then it’s a 6 db/octave roll off after that. The Le is what denotes a good speaker, the lower the inductance the more accurate the amp can drive it. There becomes a tradeoff, the SPL will suffer when the coil gets too small, and enormous amounts of power are required to make the fields to move the motor.
(3)WmAx: Le, in itself, is irrelevant to woofer quality. Le can only have an effect on the output, if said Le is of sufficient value to be reactive within the bandwidth the woofer is used within(thus it acts exactly like, and is a low pass filter). Other than Le affecting frequency response, which it won't, if a woofer is used within it's intended bandwidth, Le affects nothing else that is of audible relevance.
Analysis: In (1) I state that
Le is irrelevant in a subwoofer. I state that
Le dictates high frequency response. It is a fact that high frequency response limits the high frequency response of a woofer. I did not say anything about this being relevant to the bandwidth in which the woofer is intended to be used. You follow up in (2) and state
The Inductance of most woofers is too small to make a difference. A 4-ohm speaker, with 23mH inductance won’t start to cut off until around 1.7KHz. Then it’s a 6 db/octave roll off after that. I respond in (3) by saying
Other than Le affecting frequency response, which it won't, if a woofer is used within it's intended bandwidth, Le affects nothing else that is of audible relevance. to clarify my initial statement, since you seemed to assume I meant something that I never said. I never stated that inductance affects a large woofer/subwoofer within it’s intended passband. You assumed that’s what I meant.
It is only valid if it can be referenced to a measurement. Do you agree that impedance has an effect on the performance of a driver with a given amplifier? IE, some amplifiers have a harder time with loads that vary wild
Yes, impedance
can effect performance of a driver with a given amplifier. It is an issue only in the cases that a speaker has a very low nominal impedance that is below what typical amplifiers are designed to use
or the amplifier has a very high output impedance(not common).
-Chris
